Z-Poxy Filler Issues http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=21917 |
Author: | LuthierSupplier [ Mon Apr 13, 2009 9:06 am ] |
Post subject: | Re: Z-Poxy Filler Issues |
Todd, I just had the same problem on one I'm doing, but EIR. I left the pores and started the french polishing, and after it started getting shiny, I filled with med CA. Sanded back, and viola, pores filled! Started FP'ing, and looks great. It is time consuming to use CA, but it worked great. |
Author: | Bill Hodge [ Mon Apr 13, 2009 9:43 am ] |
Tracy, when you filled with the med CA and sanded back, what did you use to wipe it down with? Did you use the black CA? If not, it sanded clean and didn't leave any white looking splotches? |
Author: | woody b [ Mon Apr 13, 2009 10:37 am ] |
I tried Z-poxy with basically no luck. Afterwards someone told me it was probably old. I haven't tried it again. My current process is to seal with 2 or 3 coats of shellac and then fill with CA, either medium or gel, depending on the wood. I don't color it, and there's no white residue. I don't use accelerator, because I ALWAYS use too much when I try. Remember, you're only filling the pores with CA, not sealing or finishing the guitar. On wood with really tough pores like Panama Rosewood I use one filling with gel, wait ~1 hour, the 2 with medium, ~30 minutes between coats. That's usually enough. I sand with a RO sander and 400 grit beween fillings. I wait overnight, a couple more coats of shellac. Another overnight wait, and then start finishing. I use nitro. I've done one guitar with EM6000, and liked it, but I'm waiting to see the long term durablilty. Again, according to what someone told me, make sure your z-poxy is fresh. I see no need to strip if you want to use CA, just sand it and seal with a couple coats of shellac. |
Author: | LuthierSupplier [ Mon Apr 13, 2009 12:00 pm ] |
Bill Hodge wrote: Tracy, when you filled with the med CA and sanded back, what did you use to wipe it down with? Did you use the black CA? If not, it sanded clean and didn't leave any white looking splotches? Bill, I'm using clear medium CA. I always use Naptha to clean after sanding. There are a few white spots in the pores, but very few, and the shellac melts them anyway. I haven't seen any issues so far with this method. In this pic, the back was z-poxied and french polished, and the sides were z-poxied, then shellaced, then filled with medium CA, then fp'd again: Attachment: DSC_1002.JPG
Author: | Todd Rose [ Mon Apr 13, 2009 12:19 pm ] |
There are little men in the pores pushing the epoxy out and snickering maliciously. It sounds really frustrating, Todd. Wish I could help you. I'd be doing this ![]() Malicious little men image notwithstanding, it almost sounds like static electricity or something like that is resisting the epoxy in the pores. ![]() |
Author: | dmills [ Mon Apr 13, 2009 12:29 pm ] |
When using CA for pore filling, do you need to squeegee the areas flat like with z-poxy in order to work the CA into the pores? |
Author: | LuthierSupplier [ Mon Apr 13, 2009 12:42 pm ] |
dmills wrote: When using CA for pore filling, do you need to squeegee the areas flat like with z-poxy in order to work the CA into the pores? I tried that with a credit card, and found it was too much work. I just put a glove on my hand and used my index finger to smash it into the pores. Then I wiped it off with a paper towel before it started to harden. I worked a 1/2 a side at a time. A little bit goes a long way, so don't flood it with too much. About 1/2 a dime in size is plenty to work 1/4 area of a side. |
Author: | Bill Hodge [ Mon Apr 13, 2009 3:43 pm ] |
Tracy thanks for that because I've been very interested in the CA method ![]() Todd Rose wrote: There are little men in the pores pushing the epoxy out and snickering maliciously. Todd, thanks that it explains it in a way I can understand ![]() |
Author: | gozierdt [ Mon Apr 13, 2009 3:45 pm ] |
Todd, I don't know what is causing this, but I've used the heating technique you describe on several mahogany boats- I let the boards sit in the sun all day, then applied epoxy as dusk hit (part of the "West System" technique). I think I remember you mentioning working on boats also, so maybe that's where you have used it. Anyway, with as much epoxy as you've already applied, I think I'd try that technique first. |
Author: | Bill Hodge [ Mon Apr 13, 2009 3:49 pm ] |
Gene, It would probably help to use the shop vac and suck those little men Todd was talking about out of the pores. ![]() |
